The issue may not be the key. If it will crank with the key in the start position, and will run (if it fires when the key is turned to run) in the run position, it may be OK. Most key switches maintain the ignition connection when starting because it is not a separate switching action. The ignition coil may not be firing while cranking because of low voltage to it. Low voltage can be caused by a weak battery. A set of too small battery cables (00gauge is needed, including ground strap) a out of spec ballast resistor (if it has one) a poor coil 12 v coil with no external resistor required used with a ballast resistor. or combination's of these issues. A 6 volt coil needs at least five volts when cranking (it will have an external resistor) a full 12v coil (No resistor required) needs at least 10 volts when cranking. A 12v coil that needs a resistor is just like a six volt coil in reality, and needs 5v at least when cranking. If there is voltage when cranking, it is the amount that is an issue. If none, it might be the key. Good luck, JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
