Posted by Tom Fleming on October 27, 2009 at 18:11:43 from (206.193.247.91):
In Reply to: hand crank pin? posted by Mike CA on October 24, 2009 at 02:30:55:
Just a couple of quick comments here. First off, I won't debate that cold roll won't take hardening like a higher carbon steel will, but it can be hardened to a point, and it definately can be case hardened (which is what I outlined). You can even get a better case harden by using charcoal, but that takes a bit more time. Cold roll will definately not take a temper either, so no debate there. There are a couple of ways to make cold roll harder than it comes from the store, but I do agree that it is nothing like high carbon steel.
So, I have agreed on a couple of points. Case hardening will prevent wear to the pin, and I have a couple of 'crank" start repairs to prove it......ain't no battery on my F-20.
Was trying to help Mike out with what I believed would be representative of the original pin. Roll pins will absolutely work, but for his H, they won't look original. I suggested steel rod stock that is readily available. Also, cold roll is easy to work with common tools like a hack saw, and a bench grinder.
Sounds like I am being a bit defensive, and maybe I am a bit, but I don't disagree that high carbon or tool steel will definately harden to a greater extent, and yes Virginia, cold roll steel cant be tempered. so I guess my bottom line is that Mike has not received any "bum" info here, just some that is easier to implement than others........
ps. do a search on "hardening mild steel" on the net...........
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
