Posted by Mike CA on October 25, 2009 at 14:54:50 from (99.28.152.102):
Upon suggestion from this thread: http://ytforums.ytmag.com/viewtopic.php?t=548514 I turned the bracket upside down to see how that will affect my genny belt replacement. Here is what I found, please offer suggestions...
The bottom bracket, as you may know, has it's holes off-set. So when I flipped it, it pulled the genny back. That pulled the belt out of alignment, as shown here:
The flipped bracket also raised the genny, which put the belt very, very close to the bottom of the water pump, as seen in these 2 pics:
With the bracket flipped back, how I originally intended, you can see the clearance under the hood. But if I stretch it out to tension the belt, I get awfully close to the side of the hood. It may even hit. Hard to tell without the radiator on.
So, I'm not sure what to do. Buying a new belt may be expensive. I could drill out new holes in the bottom bracket to pull the genny forward to align it with the engine pulley, but I don't know if it will clear that water pump enough. I can only hope that it does.
What do you all think I should do at this point?
Oh, and a question was asked whether my genny pulley is adjustable... yes it is. When I tighten it, the slot for the belt has a larger diameter, tightening the belt.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
