First of all, it depends where you live. Here in New York at present, we have three different diesel fuels. All different, it's NOT just the color. In some other areas, it differs.
Heating oil grade is what farm fuel was until a year ago. It has the most lube in it, but is now illegal to use in any engine. It is dyed red.
Now, farm and off-road diesel is medium-sulfur with less lube, but not as low as on-road ultra-low sulfur. It is also dyed.
Highway ultra-low sulfur fuel is legally required to have a lube additive put into it - to make it safe for older mechanical injection pumps - like your's.
The main question is - since additive is expensive, are you always going to trust there is enough put into your highway fuel?
Stanadyne Roosamaster, Bosch, and CAV all call for fuel that has enough lube to make no more than 460 microns. The number is just a measure of metal wear. The lower the number, the less wear. So, mechancal pumps are designed for "460 micron" fuel. All the low-sulfur fuel AFTER the additives are put in - is rated 520 microns. That causes excessive wear according to tests. That's why there are so many fuel-lube additives on the market for diesels.
Cheap insurance is to just add some two-stroke oil to your diesel. It is the most cost-effective way to ensure your fuel won't cause premature pump-wear.
Add two-stroke oil at a 200 to 1 ratio, and it brings "520 micron" fuel down to 360 microns. That is pretty cheap insurance.
Stanadyne lube additive does the same when added at a ratio of 1000 to 1 - but it's expensive.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
