Posted by pete 23 on October 20, 2009 at 11:38:32 from (173.87.147.73):
In Reply to: 756D posted by Icuby on October 20, 2009 at 10:45:27:
I am going on the assumption this oil pump is the externally mounted one normally used on a D-310 in a 756. Some applications used a internal pump with this engine. There are two styles of pressure relief valves, 756 should have late style. Just be real sure you used correct replacement spring, I am not 100 percent sure but I think the old one piece relief valve plunger used a stronger , longer spring. If you still have the old one try it and make sure the two plungers are installed correctly. Your oil pressure is way to high for that engine. Another thing on these engines. You have to be doubly sure you have correct oil filter. It needs the one with bypass valve in the filter. The filter for 400 series engines will screw right on also and it does not have bypass in it as it is in the base on those models.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
