Remove the large threaded cap on the front of the steering sector. Loosen the 2 set screws on the forward shaft locating collar at the steering wheel support. Uncouple the u-joint and rotate the steering shaft so it un-screws itself out of the steering sector. Note: there may be lube that will drain out. You may need to "assist" the u-joint as it slides off the end of the shaft. Remove the half-moon key, clean of the shaft & out it comes. I suggest replacement of the shaft seal at this time and use corn head grease for lube upon re-assembly.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
