Posted by M Diesel on October 12, 2009 at 10:28:39 from (12.24.61.12):
In Reply to: Adding STP to gear oil posted by farmallhfan on October 11, 2009 at 09:07:01:
Fix the clutch drag.
Then use just about any ordinary gear oil. It will work fine.
Those transmissions are lubricated by gears splashing oil around, and even have a slinger gear to help the process. This technique does not work well with thick oil and at a certain thickness it actually significantly under lubricates and accelerates wear. Obviously heavy loads hurt the most.
FYI, when starting an M it takes 10 to 30 seconds before oil fills the tray and reaches the shaft bearings. In the old TD crawlers, thick oil in the final drives will wipe out the pinion bearings in a fraction of their intended lifespan.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
