Posted by Larry B 1486 on October 02, 2009 at 19:42:10 from (67.142.161.29):
I have a 1486 that I had the pump rebuilt hoping that it would help on the power. Had the injectors rebuilt also. The tractor starts good, uses no oil but does not have enough power. I have a 1466 also that will drag the 86 around the world backwards. I use both of them to pull a round baler that needs around 120 hp. The 66 handles it fine, under a load it opens up will pull that baler up a hill at 6-7mph and never slow down leaving black smoke seen for miles. The 86 in the same gear, most the time high 1 will pull the motor down to where I will have to pull the TA back and then lucky if I make to the top of the hill. It pulls the motor all the way down with very little smoke. they told me they turned the pump 10% up from factory. I backed out the screw myself one more turn and still don't have the power it should have. The timing is set 18 degrees. Any suggestions on getting more power?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
