if you're going to be shopping around at other than a CaseIH dealer.
That 11/16" inside diameter is commonly referred to in a "nominal" size as a 5/8" washer, i.e., it's made to fit around a 5/8" bolt. Trick is that it's quite narrow, about 3/32", much more so than a common washer.
It's fading some, but the more common application for that type of washer is on automotive motor oil drain plugs. Second trick is that a lot of those anymore, where they still use them, are metric.
The thought is that you may be able to find one locally for that application. If you have the center bolt out anyway, take it with you and try a 5/8"/16mm drain plug gasket for fit. It might just do the trick.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
