Janicholson said: (quoted from post at 16:15:44 09/27/09) The best info I have is to assure all control valves are returning to neutral. The hydraulics are open centered in that position. The filter can cause restriction causing cavitation and pump damage. Cleaning often loosens grime and the filter needs to be changed once after the original. Some filter systems (NAPA) and others are different, and might flow more, check that option. There should be a latch on the PTO lever that locks it into gear. Check the linkage to determine if it is operational. Do not use it slipping, it is a very expensive error. Good luck, JimN
The hydraulic valves on the 460 are NOT open center. The system is a closed center system with an unloader valve to dump the oil back to reservoir when there is no demand from the valves.
The orifice/screen assembly in the control block allows oil to flow through and open the unloader valve. When any of the hydraulic valves are moved the oil flowing through the orifice is dumped and allows the unloader valve to close. That allow the system to go on high pressure.
The standby pressure on the system should be about 60 PSI. If the orifice becomes plugged or there is too much leakage through the valves the system will stay on high pressure.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
