Three items. The shredder has an optimal RPM when used, This is not likely to be 540rpm of the PTO.
The PTO should drive shaft to the shredder, not a belt. Belts on three point systems will not be able to be adjusted correctly, as changes in hitch location will change the tension.
The use of a right angle gear box with an appropriate ratio to drive the shredded would do it.
I would consider using a separate engine on the shredded.
If you are good with fabrication, a differential with its spider gears welded, shortened, with one axle cut off and capped over, could be used. Driven from the axle , and power taken from the pinion, would increase speed, and make a right angle. This is however an engineering task, with welding and structural challenges. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
