Posted by Red Mist on September 26, 2009 at 06:37:28 from (72.171.0.148):
In Reply to: Super M choke throttle posted by Chuck Higdon on September 26, 2009 at 05:50:52:
You did not mention the color of the exhaust when it is warmed up and starts to sputter.
If it is emitting black smoke, it is running too rich for being up to operating temperature. To remedy, you will need to adjust carb settings or adjust float level. If that is the case, then go ahead and completely rebuild the carb while you are into it.
If it is NOT emitting black smoke, then it may be running lean. Possibly the lean condition is the result of an air leak somewhere between the carburetor, manifold and the head. Or, there may be trash in the bottom of the gas tank that partially blocks the flow of fuel to the carb. There is also a screen fitting where the fuel line goes into the carb which may be dirty.
If you have no black smoke, no air leaks and good fuel flow, then it is time to do a spark check to see if you have a weak coil or condensor.
If you have good fuel flow, no air leaks and good spark, then check your valve lash. Should be .017" hot.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
