Posted by ScottyHOMEy on September 18, 2009 at 07:21:49 from (64.222.247.18):
In Reply to: Super A Running Hot? posted by Pete 7 on September 18, 2009 at 05:50:52:
If you're running straight water, it will evaporate some, but I suspect the level that it's falling to is it's natural level, as there is just about a quart's difference between the top of the neck and where it will settle down to on its own.
You couldn't rule out a crack in the head or a bad head gasket that's letting some of your coolant get into the cylinder and burn off as steam, but you should be noticing the steam (as white smoke) if that's the case. If it's running right, I'd consider this the last thing to look at and only when everthing else has been eliminated.
I'd try draining and refilling with 50/50 antifreeze and water and see if it drops down to one level and stays there without overheating.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
