For original 6 volts POSITIVE ground, the batteries + goes to case/frame/ground which could be the frame or a bolt where starter mounts to frame etc.........The batteries - goes to the starter switch.
Since you had it at Neg ground you may wanna first Polarize the genny by momentarily flash jumping a wire from the BAT side of a Cutout Relay over to its other GEN/ARM terminal and you should get a spark. If it had a Voltge Regulator you could polarize by momentarily flash jumping from its BAT terminal to its GEN/ARM terminal or from BAT direct down to the gennys ARM post.
If it was Pos groud and got changed to Neg ground the ammeter leads need swapped side to side otherwise it will read bass ackwards. Similar if it were a coil distributor ignition instead of a Magneto the coil leads needed swapped i.e. for Pos gorund the coils lil - wires to ign switch and + to distributor but opposite that for Neg ground.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
