Posted by Jim Becker on August 21, 2009 at 14:13:04 from (173.57.157.82):
In Reply to: 240U 3 point posted by IH fan on August 18, 2009 at 15:04:36:
I've seen pins sheared off so cleanly that the broken part fills the hole and makes it almost impossible to see. That seems unlikely in this location, but are you sure there isn't a hole in #1 that is filled with a broken pin?
The limiter (#2) is supposed to pivot (front to rear) on the 2 pins that attach it to side plates (#4, #13). You should be able to move it until the ends of the straps (#15, #16) line up with the eye-bolt. The limiter has to pivot for the ends of the straps to follow the radius of the eye-bolt as the lift is run up and down. Could the limiter have been welded to a fixed position? Maybe by the same guy that welded #17? If so, the eye-bolt probably broke the first time he raised the hitch after he welded it. You can probably have a new eye-bolt made, but it may be the least of your troubles.
The rear weights for that tractor were split type. But one-piece weights from an A or B will bolt right on (at least if you have standard type 24" wheels) and should be easy to find.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
