A knocking sound when an engine misses is not uncommon. Especially if the misfire is a preignition when well warmed up. Several things can cause it. High heat range plugs, Worn plugs, Carbon deposits, Poor gasoline grade (regular unleaded pump gas is just fine), Irratic timing from a cenrtifugal advance mechanism going to the "weeds", or from point bounce from a bad spring, or from a loose bushing in the distributor shaft causing irratic dwell (No feelable play should be in the shaft. Less than .001" radial movement. A stickey valve will also make the same noise. Good luck with this laundry list. JimN
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
