Posted by David Goode on August 17, 2009 at 18:03:30 from (66.82.9.15):
In Reply to: Oil in SM brakes posted by Todd L on August 17, 2009 at 17:37:01:
Here were the instructions given to me when I had to replace the oil seal on the brake shaft. I drained the transmission and replaced the transimssion oil at the same time. remove the brake adjusting bolt then 5 bolts in cover and remove. Slide brake shoe from splines and seal is there in plate inside shoe rubs against. If you look for a parting line between plate and housing that supports differential and bull pinion you can find some slots to pry plate out. It has a snout to inside with an oring around it so most times it comes out kind of hard. When you get plate off seal is in it. Another way that I use sometimes is rig up a slide hammer to screw in the 5/8 fine threads in end of bull pinion shaft and bring shaft and plate out together. Shaft will slide right back in if wanted. Most places can match up the seals. If you need a new oring they are high from IH now. Used to get them from one local bearing supplier but they moved out of state and haven't had much luck finding them since. I hope this helps, I found that it was a pretty easy fix, I would also recomend replacing the oring when you replace the oil seal. -David Goode
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
