The hoses goto your joystick valve. One is pressure the other is return. The piece that the hoses go into is the power beyond plate. Thats the part you need and it bolts to the left remote hydraulic valve under the seat. You will need a straight thru valve not the end type valve your tractor most likely has now. You will also need to cut a hole thru the left cast seat support for the hoses. One other option is to connect to one of your rear remotes and tie the lever in one position. That would have oil flowing thru your joystick valve at all times. One draw back is you lose the use of one remote for other purposes.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
