Posted by ScottyHOMEy on August 16, 2009 at 19:56:12 from (64.222.221.57):
In Reply to: oil detergent or not posted by tim mcconley on August 16, 2009 at 19:23:16:
david g is on the mark.
A little kerosene and a brush used to clean up the top end, followd by a good drain and cleaning of the pan is all you need. Then run a detergent oil.
Detergent in terms of a motor oil is not the same term as doing your laundry. In oil, it is not a solvent, it is a surfactant, rated for its ability to hold particles and sludge n suspension to get them to the filter, or to hold them in suspension until drained. It does not imply (scrubbing bubbles) that will break loose clods that will clog the oil galleries. It can actually be helpful over time by allowing particles in the soft surface of inaccessible sludge to lift and be suspended or filtered out.
As far as the bearings, I think the face of the conventional main and rod bearings is a much later and more durable alloy than babbitt. They are most definitely not poured babbitt bearings.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
