Re: Clutch stuck after pressure washing
Posted by glennster on August 11, 2009 at 17:39:29 from (24.14.63.246):
In Reply to: Clutch stuck after pressure washing posted by Chad504 on August 11, 2009 at 17:17:34:
not an uncommon problem for the disc to stick. if you can get the tractor pointed in a safe direction, get it started and warmed up in neutral. then shut it off, slip er in 3rd or 4th, block the clutch pedal down with a 2x2 that you can easily remove from the operators platform, then start it up and drive around. stomp the brakes several times to see if you can get the disc to break loose. it should pop loose. once you get it loose, slip the clutch a few times to get the rust off. prolly need to relube the throw out and pilot bearings too.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
