The T/A has a small clutch in the center housing. Dirrect or high T/A depends on it holding. If the shaft that goes in the center housing that the T/A handle linkage goes to turns clockwise (looking from left side of tractor) enough to move the T/A clutch release bearing away from the pressure plate fingers, adjustment is not the problem. If it happened all at once with no noise, the splines may be worn off that clutch plate drives from. T/A pressure plates usualy make some noise when they start comming apart. If its not adjustment problem you can remove plate on top of T/A housing and see T/A clutch.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
