Posted by KARL F on August 06, 2009 at 08:58:26 from (209.188.106.159):
In Reply to: 656 Hydraulics Quit posted by Formerly PaMike on August 05, 2009 at 17:57:20:
similar just happened to us and our 656. Lost pto and hydraulics while under heavy pto load. all of a sudden we had gears grinding too. barely had hydraulic or pto with no load. turning the steering wheel would cause the gears to grind teeth. Splitting the tractor we found the pto driven shaft rear bearing snap ring came out of place, the driven shaft floated to the rear, causing the front needle bearing to be damaged by the driven gear. We had visibly damaged driven gear and pump gear teeth too.
If this happened to you, best case is a rear split, worst case is a double split. you may have to replace the pto gears and pump gear as well. Once you are in that far, the TA should be inspected and considered for replacement. replace your axle seals before putting her back in service as well.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
