We split wood for years using a 3pt splitter and the hydraulics on the 856. It was adequate for our needs. When we got the 5220 Maxxum we started using that because the little 4-cylinder Cummins used less fuel and the hydraulics were rated at a higher GPM and PSI. It is faster, but still nowhere near as fast as a tow-behind with a two-stage pump.
No way I'd use the onboard hydraulics on a Cub or 200, or any of the letter series tractors unless I really liked to split wood and had nothing better to do. Even a Super H or M with a live pump only gives you 1200PSI at 12GPM. Right up through the 350/450, these tractors have tiny reservoirs and the oil will get hot real quick.
With the "littler" tractors, do what everyone else is saying and get a pump driven off the PTO. You'll also need a reservoir that holds several gallons of hydraulic fluid.
A self-contained tow-behind splitter may be the more economical alternative. Most of them tip to vertical for the really heavy logs, and sit up at a nice working height horizontally for splitting the small stuff.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
