Posted by ScottyHOMEy on August 05, 2009 at 09:45:28 from (71.241.207.137):
In Reply to: Newbie tool question posted by Rossputin on August 05, 2009 at 09:12:18:
I just use the drive head of a 1/2" ratchet on the drain and fill plugs.
For the pans on the final there's no real drain. You have to remove the ten bolts holding each one up and drop the pans to empty them. The refill is a plug of the same type as on the tranny, and is located in the cast iron of the final drive itself, on the inside and just above where the pan mates up. Refill takes about three pints and should be at the level that it just begins to run out the fill plug. (This is where the pointed snout on the quart bottle of gear oil comes in handy.)
Pretty straightforward, but would caution that you might want to have new gaskets for those pans on hand before you drop the pans off. It's common for those old cork gaskets to break when removed. With them being actually submerged in the oil inside, it won't do to have a crack in them.
The finals will leak from the axle and diff shaft seals so they do get low on oil, but they aren't as prone to taking on condensation as transmissions. Some folks will just top them off, and you may want to do that until you have some other need, like a leaky seal, for taking the pans off. (Sad to say, but a full charge of oil in there may show up a leaky seal sooner than you'd expect!) If you want to change it, I'd recommend the gaskets, IH part# 43245D. Case IH, CaseNH dealers can get them for you. Or about any mainstream tractor dealers other than the green ones.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
