Posted by El Toro on August 04, 2009 at 17:07:11 from (205.188.116.73):
In Reply to: Cub Eng. rings posted by Darock on August 04, 2009 at 08:39:18:
When you get the pistons out you should push your new ring in the cylinder and measure the ring gap. The compression rings should be between .007-.017". The old one piece oil ring is .007-.015". They're probably now using the 3 piece set with 2 rails and an expander. You need to use a ridge reamer to remove the ridge at the top of the cylinder so you don't break a piston. I would use a glaze breaker on the cylider walls too. I would prime that oil system before you make a start to make sure you have oil pressure. If that block is sludged up I would pull the engine and take a look at that oil pump & have the block cleaned. You probably should have the crankshaft measured for wear. Hal
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
