We really need to know what the charging voltage is. There might be nothing wrong with the system at other than an ammeter that is a bit more sensitive than most, as indicated by the amount of discharge with just the switch turned on.
The battery gets drawn down when the starter is used and will except a high charge rate for a period of time as it recharges. The amperage should drop down as the battery reaches full charge. As long as the charging voltage is no more than eight volts at the battery you should be alright. Closer to seven volts would be better.
A fully charged six volt battery should have 6.3 volts. 6.5 volts will charge the battery but it will take a long time. A tractor that is used regularly for more than short periods at a time will be OK with a charging system that maintains 7 volts. Much more than that and you will have to keep adding water to the battery. Tractors that get run less frequently and for short periods at a time will do better with a higher charging rate. The higher the voltage the quicker the battery will recharge. The higher the voltage maintained while charging, the more likely you are to boil out the water.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
