Posted by pete 23 on July 29, 2009 at 10:15:20 from (173.87.13.168):
In Reply to: Governor Parts? posted by Bill in IL on July 29, 2009 at 05:16:12:
Worn out weights and pins ordinarily make a governor very slow, not over speed. I drill them out and use oversize roll pins, have to use slightly smaller drill in weight retainer than in weight so pin is tight in retainer and free in weight. Also, if you do use a roll pin, position it so as the pivot point on roll pin is not over the groove in the pin. Make sure your govenor thrust bearing is good and intact and the washer is in behind it next to weights and if you have had the gear off shaft, key could be missing allowing weight assembly to turn freely on it's own. The 6 cyl engines didn't use a key and if the nut wasn't tightened correctly this would happen to them. I am going to assume the linkage between gov and carb are installed, adjusted and lined up correctly.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
