mattofvinings said: (quoted from post at 03:39:36 07/27/09) The seal and a speedisleeve probably isn't too bad. I think I might try that first unless I was convinced by other evidence that the bearing was bad.
The difficulty on the bearing probably depends on how much press-fit was used...and...you'll probably have to concoct a puller and a pusher to install it without damaging the new one.
Thanks for the reply. I am pretty sure the bearing is shot because the shaft shown in the picture has considerable play. I assume there is also a bearing/seal associated with the part that spins underneath the shaft (not sure what it is called, maybe counter rotating shaft?) I have a puller that I think will get the existing bearings out but getting them back in could be a problem (as you suggest). PS, I have a service manual on order maybe that will help me understand what I am up against and give me the part numbers for the bearings/seals and gaskets needed to perform this work.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
