Re: Farmall m transmission gearshift will not go side to ...
Posted by TomH in PA on July 26, 2009 at 16:13:44 from (67.142.130.44):
In Reply to: Farmall m transmission gearshift will not go side to side posted by allan Kropelnicki on July 26, 2009 at 15:56:25:
Are you sure it's in neutral? It sounds like it's also in some other gear besides the two you can shift into. Take the shift lever out and look inside at the rails to see if one is out of place when you have it in neutral, that happens a lot with old Farmalls. You'll need a long screwdriver or small pry bar to get it out of gear if that's the problem.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
