Just keep in mind that an extended hyd cylinder with plugged ports/hoses and a load on the rod is at static equilibrium...but the fluid pressures are not in equilibrium!
The mechanical force/load on the extended rod is creating a pressure differential across the piston seal. Higher pressure on the bottom of the piston and lower pressure on the rod side of the piston. It is an easy thing to visualize with pressure gages.
If the piston seal cannot maintain the pressure differential (IOW leakage) then the pressures will slowly equalize by virtue of the rod being forced completely into the cylinder and the piston resting on the bottom of the tube (or at any other mechanical travel limiter).
IMHO what you have described is an excellent test to isolate the spool from the piston seal.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
