If you changed the pump position that much most likely the pump is out of time.
With the engine not running the the rear timing mark should be about the middle of the access opening in the pump housing. Roll the engine over by hand in the direction it normally runs, clockwise, and stop at three degrees BTDC. At that point the two marks should line up. If you do not see the front mark turn the engine one complete turn and recheck. After you make a timing adjustment turn the engine two complete turns to verify that it is correct. Only turn the engine clockwise to check the timing. If you turn it counterclockwise the marks will not line up the same due to play in the gears and pump drive.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
