When i looked at my 656, the rear drain pipe drops straight down to nothing. The oil stream pretty much goes down between the bull gears and behind the differential--a wide open space! removing the bull plug in the front of the housing would be slightly more beneficial to the left side of the differential but not enough to really matter.
i looked at the caseih parts site on the 2606 and can tell you that the only way you could remove the drain pipe plate would be either through the pto opening or by removing the draft housing. at least the lower link sensing models give you an access hole above the pto because of the 3rd link mount. But, for you a sawzall sounds easier!
tomorrow night will be the beginning of running my tractor with the modification. soon as i install the hyd pump gear (pto driven shaft bearing went out taking the gears with it...was a good time to do all the little things while waiting for major parts). Between new gaskets, seals, and o-rings; along with the standpipe modification, the top end of the tractor should be leak free for a good time.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
