Posted by hoppy50680 on July 22, 2009 at 16:23:25 from (75.104.160.36):
I recently bought a 656 IH that has an IH carb on it. it was running fine but needed gas. I put in 10 gallons of the 10 percent ethanol and all of a sudden it wouldnt run unless you had the choke pulled out at least half way. I tried draining the gas from the carb, that didnt help. cleaned out the sediment bulb, didnt help. finally took the carb off and apart and used compressed air to blow out all the ports, reassembled, didnt help. next I got some carb cleaner and removed the carb and soaked it in the carb cleaner over night.. since I had it all tore down I put in a repair kit. now it will only run with the choke all the way in(open) even when cold. it also spits out black smoke and the mixture adjustment has no effect at all. the only thing I didnt do when I installed the kit was to check the float height. could this be my problem ??
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
