The bypass wire causes the tests to be invalid due to the voltage coming to the fault from both sides. One other thing, if the bypass allowed the system to work some, and charge some, and discharge some, the fault may not actually show up as it could if the fault had not been stressed by the current going through it. I would definitely remove and clean each connection, then use a bit of silicone grease to reassemble the clean connections. But clean is a must. The jumper wire is like bypass surgery. Not as good as unclogged arteries, and might give a false sense of wellness. It (in this case) is possible to repair the original arteries. The worst case is that the bypass bypasses the amp gauge, and could result in runaway voltage from the alternator melting and burning the alternator and wiring as well. JimN
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
