All is well till you get to the word "Now". Run a wire from the #1 post of the alt to a marker light bulb (by its self), or the marked end of a 3 amp 100piv power diode. the other terminal of the light bulb or non marked end of the diode goes to the same terminal on the key switch, or the coil + terminal(if it has a 12volt coil no external resistor needed), or to the Key side of the external (ballast) resistor (it needs a ballast resistor if it has the original 6v coil, or a 12v external resistor required coil). This allows the alt to know when to charge, and when to stop charging. The original VR should be discarded (or given a rest under the bench. The green wire is not used. The resistor is not needed if the coil measures twice the resistance across its little terminals than a 6volt coil. It will work well. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
