It is a Roosa Master pump. The window I am talking about is a little plastic,"window" that one installs where the little cover on side of pump is. It takes an understanding of the operation of the pump to do you any good. It is so you can observe movement of the automatic advance while engine is running and make adjustments if necessary. To just check the timing you take off the side cover like I said. It is just a little rectangular plate about an inch and a half long by maybe 3/4 inch wide. You didn't indicate if you had pump off or not so I just figured you wanted to check the static timing. If you are installing the pump, you will need to find number one tdc, like take out number one glow plug and turn engine until you have compression coming out and then align pulley one degree mark with the pointer. Then turn pump until the marks in pump align and install. Recheck by turning engine backwards a ways and again turn to one degree on pulley. I don't have pictures to post, not into that end of it. Also, are you having a problem with the engine or just checking it out.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
