What I would look for next is what happens when you give the steering wheel a slight "crowd" in either direction with wheels fully engaged with the ground.
What I would expect is pump pressure would rise as the spool moves and forces the boost/assist cylinder to move, then as the spool re-centers, the pump pressure would then drop back to zero (open-center/spool-neutral condition).
Another mental abstraction to think about (or from the viewpoint of) is that the system doesn't exactly "demand" pressure in my thinking. In retrospect, it "creates" backpressure (what the pump-output gauge is reading) by virtue of creating an effective restriction to fluid flow or presenting the ever-adding positive-displacement volume of fluid against a mechanical load (as in the case of a hydraulic cylinder).
Just a practical example of above, with a functioning system I would fully expect pump backpressure to be significantly lower when turning the tires on a film of slick mud vs. when they are half-buried up to the axles. In other words, even though the pump can produce 1400psi when thoroughly dead-headed, the pressure is "matched" to the mechanical "resistance" load applied in the opposite direction.
This post was edited by mattofvinings at 16:41:34 06/20/09 3 times.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
