My mystery is solved, and I thought I would post for future reference, so no one else has to go through my trouble.
There are 2 ball-joint inserts for the center steering arm. One is flat on one side, and rather thick 1/2" (thicker than the ones for the tie-rod ends). It goes at the bottom (end) of the blind side of the steering arm. Next, goes the ball-joint end of the tie rod. Next goes the double sided insert. Then install the opposite tie-rod. Lastly, install the set-screw.
The inserts for the tie-rod ends are approx 5/16" thick, and are flat on 1 side. One per side, with the flat end (of course) going into the far end of the tie-rod end.
I found that I had 1 of the tie-rod end inserts "missing" as someone in the past installed 2 7/16" washers as the ball joint inserts. I thought they were just spacers for wear. Turns out, they were intended to be the insert.
Went to the local tractor grave yard, Charlie Burgh's, and retrieved another insert.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
