Hi Lynn, yes, the glow plugs are wired in series so if one is burnt out none will work. If I recall correctly on 384 you pushed the starter switch in to activate the glow plugs. The wire from the switch should go to the glow plug indicator on the dash then the other side of the indicator will go to #4 glow plug at rear of engine. The glow plug indicator is also in series with the glow plugs. So 12V/5 approximately 2V across each glow plug but due to wiring loss I believe about 1.6V is the reading you will see on a VOM. Some hints: Don't put 12V across a glow plug, most likely an open glow plug, a shorted glow plug will blow out all the glow plug connected before it. Measure each one with an Ohm meter including the indicator on the dash. IIRC the glow plugs should read less than 1 Ohm.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
