First of all The lights working and no amp gauge movement means either the amp gauge is stuck (frozen), or wired incorrectly. The lights should be wired through the amp meter to the starter switch then to the negative post of the battery. Thus when the lights are on, the amp gauge moves. The fact that it does not tells me that you may be in better shape than you thought. With it running at 3/4 throttle or above, test the battery voltage with the switch set at the second position from far CCW. This is the high charge position. It should show about 7 to 7.4 volts across the battery terminals. If it does, you are charging correctly. Turn the switch to full CCW and check the volts. 6.5 to 6.7 are good numbers on Low charge. Turn the switch to D (third from full CCW) and the voltage should be same as in the High charge position 7 to 7.4 volts. If so this indicates that the light resistor is open (bad) or the light switch terminals are not making contact on Dim. If the voltage is OK, I would check the wiring against Bob M's Diagrams and if OK, I would replace the amp meter. Let us know what you find. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
