Yes, the pto shaft has a pilot that runs inside a bushing in the back of the bottom countershaft. You can either remove the whole unit (5 bolts) which is easiest, or the seal/bearing retainer (2 bolts) and pull the shaft and engagement collar tube back away from the countershaft. The front and rear bearings of the countershaft should be removed too before trying to remove the shaft. The rear bearing has the mean snap ring that must be removed to slide the bearing off the shaft and out the back of the bulkhead that separates the transmission from the differential areas. It is tight with the gears on the countershaft but it will lift out. That is the way it went in at the factory.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
