After retiming and changing plugs, points, rotor, etc as well as rebuilding the "professionally" rebuilt carb, we finally got the A running last night and drove it around... Thats its first trip out of the garage since I got it a couple weeks ago. Let it run for about 20 mins and apprehensively cut it off to see if it would crank again... Luckily it did. Carb doesn't seem to leak anymore unless I flood it trying to crank it. The odd thing is that the main needle had to be turning all the way in for it to run right... I guess its worn that much? Seems to idle fairly high, but I'm not even sure how to hook up my dwell/tach meter to a magneto now that I think of it.
Drove it out in the yard today and got most of the grease build-up off of it. Just in time as my garden is getting overrun with spiny pigweed (new garden in old pasture...) If I can just figure out these cultivators or find some info on them.
Oh yeah, the problem with the carb/float leaking apparently was the viton tipped needle had been manually set which someone on here suggested, but the napa rebuilt instructions warned against. The kit came with new needle and seat and after carefully adjusting the float to specs while not applying any pressure to the needle, the carb worked much much better. Plus the guy that rebuilt the carb used the wrong gasket out of the kit he got...
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
