Fuel is getting TO the carb., but is the fuel getting INTO the carb?
Take it apart, remove and clean the float valve with spray carb cleaner, blow it dry with compressed air and reassemble. Double check the float height setting and also that the float moves freely.
I guess that IF the load adjustment screw is turned all the way in, which it should NOT be, then NO fuel can get into the main stem, and the tractor will not run.
The load screw should be set at 3 turns out (factory initial setting), and the idle/air adjustment screw should be set a 1 1/2 turns out (factory initial setting)
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
