Posted by John T on May 31, 2009 at 09:15:05 from (66.244.97.31):
In Reply to: 53 Super A not starting posted by Adrian Billheimer on May 31, 2009 at 08:58:16:
I'd be "looking at" a good battery charge the first thing, that may be allllllll she needs. If the points arent burned or carboned over they may be okay. Of course, leaving the ignition on may have overheated n harmed the coil, the other Id be "looking at" would be to see if the coils primary (between its lil + and - terminals) still has continuity (not burned open). An ohmmeter should show around 1.25 to under 2 ohms if its a 6 volt coil,,,,,,,,,of course, if it reads an open circuit its badddddddd..
Put a test pamp on the coils input (from ign switch) n turn her on and a test lamp or voltmeter should read hot voltage. Then place it over on the output (to distributor) terminal and there should be near zero volts when points are closed but hot battery voltage when points are open UNLESS the coils primary is burned open
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
