Posted by P and R Pete on May 31, 2009 at 08:56:53 from (173.86.0.139):
In Reply to: Hydraulic Leak posted by Farmall Bob in CT. on May 30, 2009 at 17:51:28:
Farmall Bob,
Here's some pics of mine, on a Super-A, and I don't know if the same pump and arrangement is used on a Cub, but the principles should be similar.
Here's my pump as it sits on the lower right engine case- you can find yours by following the hydraulic lines. My pump body separates into 2 pieces, and the offending O-ring (or seal,- different pumps used different ways to hold the hydraulic fluid) is in the front part of the body, arrowed.
Once off, here's the gear that extends into the engine case and is driven by the cam gear in the engine, and here is where your fluid is getting past and into the engine. The arrow points to where the washer under the nut was bent up, to act as a 'lock' on the nut.
Here's mine in pieces. (Warning- if you're going to take yours apart, make sure you have things go back in exactly from where they came out) As you can see, that outer gear is keyed, and needs to come off to extract the shaft (black arrow) on which it rides. The worn O-ring/seal is in the bore labeled #2. What CNKS was referring to is that the old O-ring/seal often wore a groove in the shaft, and you would see that groove where arrow #1 is pointing. A groove will promote leakage on your new O-ring/seal, so you don't want to miss it.
I'm holding the re-build kit I got from IH. It contains instructions with pictures. To get the right kit, you have to find the serial number on your pump. Mine was long, but very small, and I had to scrape paint to find it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
