Posted by Janicholson on May 31, 2009 at 06:03:02 from (66.173.50.177):
In Reply to: Overdrive on a M posted by BSpauld on May 31, 2009 at 05:24:25:
The device he is talking about is called a 9 speed. It was produced by several companies M&W, and Hiesler, to name 2. They are like an overdrive in some ways. and not in others. Many overdrives are after the transmission. These are in the trans affecting 1-2-3-4th gears only, leaving 5th (a direct to output shaft coupling)alone. When working it will not go faster than fifth would normally, it does give 4 gears in between the original 4th, and original 5th. Desirable yes. reparable probably. The most likely problem is a linkage issue. A stuck cable, or actuator. Less probable but worse is broken internal components and or gears. JimN
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
