Posted by John T on May 24, 2009 at 15:22:40 from (66.244.97.31):
In Reply to: smta no start update posted by paul smta on May 24, 2009 at 14:28:18:
Paul, the correct answer as far as what plug wires to use with a Pertronix high energy coil is: ASK PERTRONIX and believe them over any of us here, regardless if from engineers or lay persons........
The thing is in general terms, carbon core supressor wires may be best for supressing radio interference BUT can waste a "small" (NOTE I said small) amount of energy in the form of heat versus its discharge across the spark plugs gap. This is not so critical in a battery powered coil ignition versus say a lower energy Magneto where I recommend the use of coper core NOT carbon core wires.
HOWEVER AND THIS IS WHERE N WHY YOU NEED TO ASK PERTRONIX. In "some" high energy high voltage ignition systems (note I said some i.e. not all) they actually want a certain small degree of supression and/or inductance (such as in spiral wound plug wires) in the High Voltage Secondary circuit. NOTE IM NOT claiming this necessarily applies in your chosen Pertronix system, im just placing you on notice that in certain HV high energy ignition systems spiral would plug wires or perhaps carbon core may be specified I.E. Not having any pertronix specs or your coil or switch specs n data Im just saying CHECK WITH PERTRONIX N DO AS THEY SAY NOTTTTTTTTTTTTTT ANYONE HERE
At first blush many may recommend the use of copper core wires over carbon core and thats usually my general advice and such may darn well be correct in your case, but I just dont want to be responsible for mis information not having the pertronix specs or data or any idea which switch n coil you have, sorry. Of course, its your tractor and your choice and your bucks so whichever wires you choose or whose advice (Pertronix or us here) you go with is certainly your call. (My best non warranted guess, however, would be quality HV rated straight copper core or spiral wound versus carbon core wires lol)
NOTE whats important if you use a HV coil and run a wider plug gap is to use good quality high voltage withstand rated plug wires as you may be working at much higher voltages then with an old stock system, so DEFINITELY use quality high voltage rated wires REGARDLESS !!!!!!!!!!!!
If you need my complete Troubleshooting Procedure for no spark, click the URL link below
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
