As long as the pressure relief valve is opening, it will only affect the steering. Its purpose is to limit the maximum pressure to the steering. The steering system gets priority on the MCV pump flow but unless the steering is held against the stops, the flow bypasses the relief valve and pressure is controlled by the regulator valve in the MCV assembly. Excess flow from the regulator valve is routed to the TA lube and again regulated by the lube pressure regulator valve.
Since your problem is not constant you may want to check to see if the orifice is loose in the MCV valve. It is accessed through the port in the rear of the MCV that has a 5/8 inch hex plug. An orifice that is out of place can cause the flow to vary in the MCV circuits.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
