I have a plain M but I believe the setup is identical to that on a Super M. I had to go out and buy what is called an "offset" or "obstruction" wrench from NAPA to get at that back nut. It is shaped like a "C" and allows you to get around things that might be in the way of getting at a bolt.
Also--I found you have to be careful with lining-up the tube that comes from the governor to the butterfly shaft on the carb. If it binds in anyway you will get a sticky throttle response. I attached the carb first to the manifold with the nuts kind of loose, then connect the gov. to throttle tube to the carb and tighten the screws. Then tighten the carb stud nuts.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
