Posted by Owen Aaland on May 17, 2009 at 23:25:28 from (65.165.246.54):
In Reply to: Grease fittings posted by Hugh MacKay on May 16, 2009 at 13:15:49:
Hugh MacKay said: (quoted from post at 13:15:49 05/16/09) Roy: The manual actually calls for grease every 500 hours of operation or every 6 months. It calls for several strokes of the gun.
The one on the distributor shaft has a hole on the back side opposite the fitting. On that one when you see grease coming out that hole, you have enough. That one will put grease in the distributor if you go too much.
The fitting on the distributor drive gear housing can put grease in the timing gears and on to the crankcase if too much is used.
Harold is right, if you have yahoo's greasing, best to stick with plugs. If you alone, choose your method.
Actually the front zerk is the one that will put grease into the distributor. The distributor housing has a groove to allow the grease to go around the outside of the bushing and any excess is expelled out the hole in the back. It uses an oilite bushing where grease is absorbed into the bushing material to lube the shaft.
Over greasing the front zerk will force grease along the distributor shaft on the inside of the distributor bushing.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
